Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M5 MR5100
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-30
04:07 PM
2021-08-30
04:07 PM
Nighthawk M5 MR5100
The local RSL sub branch has just changed internet providers and now use a Nighthawk M5 router. The previous system had an external antenna with ethernet plug to connect to a router.
Can I plug the ethernet plug from the external antenna into the Nighthawk M5 router, ethernet slot ? It will fit, but I did not know if any damage might occur with wifi signal coming into a plug that might not be meant for it.
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-04-15
07:07 PM
2023-04-15
07:07 PM
Re: Nighthawk M5 MR5100
I don't think that will work. The Ethernet port on the device is for connecting a PC or WiFi router. If you set up the ethernet offloading, the port is needed to connect to your home router's LAN port.
Thanks
Message 2 of 2
Announcements
