Reply
Nighthawk(R) X4S R7800 slow wifi download speeds
System303
As the subject says the download speeds have not been good as of late over wifi.  I'm not sure how long it's been this way.  I've tried going through each version of the firmware but the results are the same about, roughly 10 mbps.  The  upload speeds is consistant, around 12mbps over both wired and wireless.  Typical speeds over wifi have been 150 mbps.  It's on channels that aren't really occupied by anyone, the 5ghz is by itself on 157.  Both 2.4 and 5 get about the same download at around 10 mbps.
I've tested the speeds over two pcs and my phone, and I've also reset it to factory settings and nothing has impoved.  I'm starting to think it's hardware related  aat  this point, but not sure how the upload could be where it's suppose to and the download not even close.
Appreciate the help in advance
Message 1 of 2
Guru
Re: Nighthawk(R) X4S R7800 slow wifi download speeds
What ISP service do you have? DSL or Cable?
What ISP Mfr modem and Model # do you have?
What Up to speeds do you have set?
What channels are you using?
What Security modes are you using?
Is QoS enabled?
Is IPv6 enabled?
What version of FW is currently loaded?
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2700 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
