- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R6700v2 not getting internet from modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, but did you read the MANUAL on-line, https://www.downloads.netgear.com/files/GDC/R6700v2/R6700v2_UM_EN.pdf? It shows you how to connect the modem and router on page 15. Did that and you put the cables in the right sockets? Need to ensure the cable you are using is good? Are you using the same one that was connected from modem to PC before? If not, use that one and see what happens.
@Cowboys254 wrote:
-The model # is CM500
-I can reach the genie page but cannot get in.
Good, but WHAT does it show when you get there? Are you seeing the USERID and PASSWORD prompt or something different?
It says there’s a problem detecting the internet connection.
I don't think it should do that unless you are trying to go to the INTERNET? What browser are you using to do this? What are you entering into the URL?
I suggest you look AT THIS PAGE and watch the video's and follow what they show.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R6700v2 not getting internet from modem
A couple of things to look at and maybe supply more info?
- What is the NG modem model number?
- The modem will generally 'remember' who it was connected to via the MAC address. You can't just plug in another 'thing'. Your PC's MAC Address is what the modem is looking for and it will not recognize your router. You need to power OFF the modem. Then connect the router and power up the modem and when it is fully up, then the router is powered up, and lastly any devices. If this works, don't need the modem model number.
- Can you reach the router's Web Browser Genie page? If so, can you get in? Can you configure the router?
For now, post back if it is fixed or the info requested?
- Mark as New
- Bookmark
- Subscribe
- Permalink
-I can reach the genie page but cannot get in. It says there’s a problem detecting the internet connection. I try the solutions but they don’t work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again.
