Reply
Nighthawk R6700v3 WDS
gh2gen
Follower
Does R6700v3 support WDS or any other option to bridge wireless to another wireless router
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: Nighthawk R6700v3 WDS
> Does R6700v3 support WDS [...]
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "WDS".  I found
nothing.  If I do that for "R7000", then I find a section entitled "Set
Up a Wireless Distribution System".
> [...] or any other option to bridge wireless to another wireless
> router
   "Use the Router as a WiFi Access Point"?  If you can't easily run an
Ethernet cable between the main router and the WAP, then a pair of
Powerline adapters might work to emulate one (for still more money).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1259 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
