Orbi WiFi 7 RBE973
Reply
Nighthawk R6700v3 and 3700 extender
Ericc0354
  1. A few days ago I noted an update to the firmware was available for my Netgear Nighthawk R6700v3 router. Using the Nighthawk app I executed the update and it proceeded successfully. The router came back online. The issue is that now I can no longer log into my Netgear 3700 extender either by the 192.168.1.250 pr the web based interface. Using Safari as my browser the route to 192.168.1.250 results in a server error after it times out. The 3700 extender has been a cranky device but this is a new issue. Any thoughts on how I can rectify? Seems like my Nighthawk is blocking access to 192.168.1.250.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 7
Accepted Solutions
Guru
Re: Nighthawk R6700v3 and 3700 extender
try factory resetting the extender and reinstall it.
Push and hold reset for 7-15 seconds while its powered on. then follow the install.
If you check the attached devices page for the router, it should have the IP address for the extender. Maybe it changed.
Message 2 of 7
All Replies
Guru
Message 2 of 7
Ericc0354
Thanks much for the hint. I had tried the factory reset on the 3700 a couple of times but still could not log into it's administration through the 192.168.1.250 address. Your suggestion to try using the IP as assigned by my main router worked! I can now review the status and settings using this method. Not sure why the 192.168.1.250 no longer works but I guess it won't matter now. Thank you very much!
Message 3 of 7
wangcheung
Tutor
I had the same issue using the latest firmware (102) for the R6700V3 although I am using another router as the AP. I reverted back one version of firmware (84) and the IP access works now. The AP now also shows up in the connected devices list on the R6700V3
Message 4 of 7
Guru
The .250 address is just a default ip address from when its not connected to the router.
Message 5 of 7
Ericc0354
Good to know I'm not alone with the firmware glitch. Maybe I'll role back a version if I can figure out where to obtain the file. Thanks for the feedback!
Message 6 of 7
wangcheung
Tutor
you can download right from the netgear site. Search for R6700V3 and then select downloads. The top of the list will be the latest version but at the bottom you can select older versions and pick the one you want to roll back to.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1239 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
