Orbi WiFi 7 RBE973
Reply
Nighthawk R6900P drops 2.4 GHz after minutes. 5GHz is stable.
Eleebob7
I have been running this for about 5 months. The router has been stable the whole time until last week.
The 2.4 GHz network stays up for about a half hour, then dies. The devices can see it, but the signal strength is terrible and they cannot connect.
I have done the following.
- Updated to the latest FW
- Changed channels: from Auto to 4 to 10 then 8. Wifi analyser shows 8 should be the best.
- Factory reset
- power cycle
I have seen a few posts about this on various models, but looks like most of the time, the channel change fixed things. Not in this case. Any help is greatly appreciated.
Model: R6900P|Nighthawk Smart WiFi Router with MU-MIMO
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: Nighthawk R6900P drops 2.4 GHz after minutes. 5GHz is stable.
Hi Eleebob7,
Use channels 1,6 or 11.
Message 2 of 5
All Replies
JamesGL
Master
Hi Eleebob7,
Message 2 of 5
Eleebob7
Thanks JamesGL.  I'll try it when I get home. Are the other channels known to be finicky?  Wifi Analyzer shows that 1 and 6 are pretty heavily occupied in my area.  I'm almost certain the issue I'm seeing is not a channel congestion issue.
Message 3 of 5
JamesGL
Master
Hi Eleebob7,
Any feedback on this issue? Did changing the channel work?
Message 4 of 5
Eleebob7
Thanks for the follow up.  Seems to be solid but my wife's phone is still having issues every once in a while.  I think it's okay so far.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1556 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
