Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 2.4ghz stuck at 80mbps on gigabit internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2016-12-16
06:33 PM
2016-12-16
06:33 PM
Since I got Google Fiber Gigabit internet, in April, I have been unable to get my 2.4ghz band anywhere close to the 600mbps cap. I have only been able to get it to about 85mbps. Is there a known issue or any way to fix this?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2016-12-16
09:37 PM
2016-12-16
09:37 PM
Re: Nighthawk R7000 2.4ghz stuck at 80mbps on gigabit internet
TL;DR It's probably normal.
You'll never get 600 Mbps for several reasons:
- The R7000's advertised, maximum link speed of 600 Mbps uses a non-standard encoding scheme developed by Broadcom, called TurboQAM. Most devices do not support TurboQAM. The highest, standard speed is actually 450 Mbps.
- To achieve a link speed of 450 Mbps requires a device to support 3 spatial streams. Only Macbook Pros, high-end PC laptops and desktops with high-end Wi-Fi adapters support 3 spatial streams. Most smartphones support 1 or 2 spatial streams.
- To achieve a link speed of 450 Mbps also requires the use of 40 MHz channels. Wi-Fi standards mandate the use of 20 MHz channels when multiple Wi-Fi networks are active. This cuts the maximum link speed by a little more than half to 216.7 Mbps. A 2 spatial stream device will have a maximum link speed of 144.4 Mbps. 1 spatial stream can do 72.2 Mbps.
- Due to the high overhead of Wi-Fi, actual speeds are commonly between 30% and 50% of the link speed.
Put all this together and you can probably expect to see ballpark speeds in the following ranges:
Spatial Streams | Speed range (Mbps) |
3 | 65 - 110 |
2 | 40 - 75 |
1 | 20 - 40 |
Message 2 of 2
Top Contributors
User | Count |
11 | |
10 | |
6 | |
3 | |
3 |
