- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 5G dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I'm having the same issue I see a lot of people are having. I disabled automatic updates and did a factory reset but upon reboot, the latest firmware is installed. And that seems to be the culprit for dropping the 5g network. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 5G dropping
You can downgrade the firmware.
You have the R7000?
Try installing the 1.0.9.42 firmware. Seems to be the most stable with devices that have 5g issues.
after the update, do a factory reset as the firmware is quite changed.
then disable auto-updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans Maybe you didn't read my text carefully. I already did as you suggest but once it was re-set to factory settings, it still had the latest firmware even though I disabled auto updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A factory reset doesn't change the firmware. it simply removes all the settings.
And you put "i'm on the latest".
It isn't a number and might not be on the latest. Especially when it comes to the R7000.
And if you'd have looked at the version I recommended, it isn't even close to the latest. Its several years old but its been the most stable version for those devices having issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LisaAyn Just be aware, that although there is this collective endorsement of firmware v.42, as has been pointed out, it's now several years old. If you really want to take the risk of running a firmware that by now is likely to have several security weaknesses, then that is entirely your decision, just make sure you've got good anti-virus etc. Personally, I wouldn't do it, but then I've never had any of the issues so widely reported on this forum. Funny that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh so true.
The "check for updates" process can miss "hotfix" versions that have yet to pass all the quality checks – yes they do exist – before the new version rolls out to the update server.
Any claims to have "the latest" are, therefore, meaningless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly not.
It you reset the thing you may have turned automatic update back on. (That is the default setting on recent versions.) So you should update the firmware with your chosen version, then turn off the automated update. Do that and it will not install the latest firmware.
As @plemans says later on in this conversation, a reset does nothing to your firmware version. It just wipes the settings, which includes whatever you did to turn off autoupdates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try two settings:
1. Set the 5GHz channel to 36 or 40 or 44 or 48
(Explanation: channels: 52,56,60,64,100,104,108,112 are in the range of DFS channels and the R7000 may disable them temporarily)
2. Change to the following setting (apparently it can help - I found it in another thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-1-0-11-123-and-5Ghz/ td-p / 2105721):
Advanced -> Advanced Setup -> Wireless Settings on both 2.4 and 5 GHz
Fragmentation Length: 2346 change to 2304
CTS / RTS Threshold: 2347 change to 2304
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all that. I'm not sure what actually "fixed" it but it seems to be holding for now. I did not roll back to older firmware as some recommended and chose to heed the advice of @Portwey84 . One thing I did do was to renew my Netgear Armor subscription. Maybe that did the trick??
However I'm happy to have your suggestions in case my router decides to act a fool down the road.
Thanks!
