Reply
Nighthawk R7000 Poor Performance
Vahle48
Follower
Bought my R7000 in January to improve coverage and consistency of 200mbps cable connection. Performance and coverage had been great...until yesterday, that is. I am now experiecing the following: inability to stay connected to either 2.4 or 5ghz - sometimes I can connect to 5ghz, only to have it disconnect or switch to orginal Spectrum crappy modem/router, low/inconsistent download speeds, sporadic streaming interruptions on multiple devices (phone, tv, etc.), poor signal, poor app performance, etc., etc. I have updated the firmware yesterday, and have performed a reset of the device three times now, but have been unable to get a strong, consistent signal, even when standing 10 feet away from the router.
Any suggestions on how to fix? Thanks!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Ctanner589
Re: Nighthawk R7000 Poor Performance
Mine has done the exact same thing... However, the only time I have had this happen is whenever there is a Firmware update. If you are using the Nighthawk app or you have a computer connected directly to the router (wireless is not recommended), you can update the firmware for the router from those.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 942 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
