Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 USB drive format exFAT not recognized
Samlinxia
Follower
My USB drive format is exFAT and is not being recognized by the ReadyShare USB drives.  Is there any solutions to that other than reformating to NTFS?  Do you have any plan to support exFAT format since it's a widely used format that can be used across Windows and MacOS?  Thanks!
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Accepted Solutions
microchip8
Master
Re: Nighthawk R7000 USB drive format exFAT not recognized
There is no support for exFAT and most likely never will be. The router runs an old kernel that needs heavy patching to support exFAT. Unlikely to be done
Message 2 of 2
All Replies
microchip8
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3408 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
