Discussion stats
  • 10 replies
  • 4367 views
  • 4 kudos
  • 5 in conversation
Announcements
Top Contributors
Reply
Highlighted
Retired_Member
Not applicable
Nighthawk R7000 VPN will not work on OSX only
Hey,
I have the VPN service running and it works on my iphone fine with OpenVPN
The service will not work on my mac through Tunnel or Viscosity
It shows that it connects but it does not change the IP or do much else.
It is driving me absolutley insane.
Router - Firmware Version - V1.0.7.2_1.1.93
OSX - 10.11.6
Latest versions of Tunnel or Viscosity
Any help would be appreciated<3 Thank you!
Log from Viscosity
Sep 07 00:01:35: Viscosity Mac 1.6.5 (1354)
Sep 07 00:01:35: Viscosity OpenVPN Engine Started
Sep 07 00:01:35: Running on Mac OS X 10.11.6
Sep 07 00:01:35: ---------
Sep 07 00:01:35: Checking reachability status of connection...
Sep 07 00:01:35: Connection is reachable. Starting connection attempt.
Sep 07 00:01:35: OpenVPN 2.3.11 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on May 10 2016
Sep 07 00:01:35: library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09
Sep 07 00:01:36: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sep 07 00:01:36: UDPv4 link local: [undef]
Sep 07 00:01:36: UDPv4 link remote: [AF_INET]24.46.2.166:12974
Sep 07 00:01:37: [netgear] Peer Connection Initiated with [AF_INET]24.46.2.166:12974
Sep 07 00:01:40: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Sep 07 00:01:40: OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.0
Sep 07 00:01:40: DHCP enabled on tap interface tap0
Sep 07 00:01:40: TUN/TAP device /dev/tap0 opened
Sep 07 00:01:45: Initialization Sequence Completed
Sep 07 00:01:46: DNS mode set to: Split
Sep 07 00:01:46: WARNING: Split DNS is being used however no DNS domains are present. The DNS server/s for this connection may not be used. For more information please see: https://www.sparklabs.com/support/kb/article/warning-split-dns-is-being-used-however-no-dns-domains-...
Sep 07 00:03:43: write to TUN/TAP : Input/output error (code=5)
Sep 07 00:03:45: write to TUN/TAP : Input/output error (code=5)
Sep 07 00:03:45: SIGTERM[hard,] received, process exiting
Sep 07 00:03:50: Viscosity Mac 1.6.5 (1354)
Sep 07 00:03:50: Viscosity OpenVPN Engine Started
Sep 07 00:03:50: Running on Mac OS X 10.11.6
Sep 07 00:03:50: ---------
Sep 07 00:03:50: Checking reachability status of connection...
Sep 07 00:03:50: Connection is reachable. Starting connection attempt.
Sep 07 00:03:50: OpenVPN 2.3.11 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on May 10 2016
Sep 07 00:03:50: library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09
Sep 07 00:03:51: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sep 07 00:03:51: UDPv4 link local: [undef]
Sep 07 00:03:51: UDPv4 link remote: [AF_INET]24.46.2.166:12974
Sep 07 00:03:52: [netgear] Peer Connection Initiated with [AF_INET]24.46.2.166:12974
Sep 07 00:03:55: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Sep 07 00:03:55: DHCP enabled on tap interface tap0
Sep 07 00:03:55: OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.0
Sep 07 00:03:55: TUN/TAP device /dev/tap0 opened
Sep 07 00:04:00: Initialization Sequence Completed
Sep 07 00:04:01: DNS mode set to: Split
Sep 07 00:04:01: WARNING: Split DNS is being used however no DNS domains are present. The DNS server/s for this connection may not be used. For more information please see: https://www.sparklabs.com/support/kb/article/warning-split-dns-is-being-used-however-no-dns-domains-...
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 11
Highlighted
NETGEAR Moderator
Re: Nighthawk R7000 VPN will not work on OSX only
Hi dejayjohn
Please follow steps provided in the KB article below:
http://kb.netgear.com/app/answers/detail/a_id/25389/~/enabling-vpn-service-on-a-nighthawk-router-usi...
JamesGL
Community Team
Message 2 of 11
Highlighted
Retired_Member
Not applicable
Yeah that does not work. I've tried those steps about 5 times.
Message 3 of 11
Highlighted
I am having this same issue with the r7000 on the latest firmware V1.0.7.2_1.1.93
Just bought it yesterday to set up a VPN, and unfortunately cant find a fix.
Message 4 of 11
Highlighted
NETGEAR Moderator
Hi dejayjohn,
Can you provide the logs on the Tunnelblick software for OpenVPN?
JamesGL
Community Team
Message 5 of 11
Highlighted
NETGEAR Moderator
Hi dejayjohn,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
Message 6 of 11
Highlighted
Retired_Member
Not applicable
yeah. seeing as nothing works. definitly do.
the logs are pasted above.
Message 7 of 11
Highlighted
NETGEAR Moderator
Hi dejayjohn,
You've mentioned that the above logs is for viscosity software. I would like to ask for the logs using the Tunnelblick.
JamesGL
Community Team
Message 8 of 11
Highlighted
NETGEAR Moderator
Hi dejayjohn,
JamesGL
Community Team
Message 9 of 11
Highlighted
I'm having the same issues using tunnelblick on my mac. Here's the logs:
016-12-08 16:12:32 *Tunnelblick: openvpnstart starting OpenVPN
2016-12-08 16:12:33 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2016-12-08 16:12:33 MANAGEMENT: CMD 'pid'
2016-12-08 16:12:33 MANAGEMENT: CMD 'state on'
2016-12-08 16:12:33 MANAGEMENT: CMD 'state'
2016-12-08 16:12:33 MANAGEMENT: CMD 'bytecount 1'
2016-12-08 16:12:33 MANAGEMENT: CMD 'hold release'
2016-12-08 16:12:33 *Tunnelblick: Established communication with OpenVPN
2016-12-08 16:12:33 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
2016-12-08 16:12:33 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2016-12-08 16:12:33 Socket Buffers: R=[196724->196724] S=[9216->9216]
2016-12-08 16:12:33 UDPv4 link local: [undef]
2016-12-08 16:12:33 UDPv4 link remote: [AF_INET]myrouterip:12974
2016-12-08 16:12:33 MANAGEMENT: >STATE:1481242353,WAIT,,,
Message 10 of 11
Highlighted
Initiate
Hi, I ran into this issue as well, it seems like DHCP isn't working on OSX and Linux. Windows and android both worked excellent!
Adding the following two lines to the bottom of my client2.conf resolved this for me:
ifconfig 192.168.1.205 255.255.255.0
route-gateway 192.168.1.1
Message 11 of 11
