- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 and Playstation Now
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello there.
I have a Nighthawk Router and I have been having trouble with trying to get connection with my Playstation Now Account, When using the nighthawk it says my connection isn't good enough to handle the connection right now but when I plug my PS4 into my modem and Ignore the router it works fine,
I'm using a wired coection and the Playstation now is like a streaming service for Playsation game (incase people don't know)
If anyone can help me with this issues that will be great,
I have also tried to restart my router and Modem and have the same results, I'm going to turn off QoS and see if that helps very soon and will keep you posted
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Narkis,
Reset the router after the update and manually reconfigure it. If you are using the QoS, make sure to set the priority of the PlayStation to High if you want it to have more priority with the bandwidth.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 and Playstation Now
Hi Narkis,
1. What is the firmware version of the router? Check support.netgear.com for the latest firmware.
2. What is the speed you can get from the router when using a computer?
3. Please perform a reset and manually reconfigure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe I need to update my Firmware as it's not the latest one,
DL is around 70mbps and Uploads is around 18Mbps
I will note that when I turned off QoS it worked but I wanted to use that as part of the router
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I updated the Firmware and put QoS back on and it no longer works,
I have tired the other options and still it doesn't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
You didn't specify from which and to which firmware version you upgraded. In any case, you should do a factory reset to erase the settings from the old version. With all the different versions floating around for the R7000, many of them are not compatible with each other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Narkis,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Narkis,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again for all the help and fast response on my issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Narkis,
Thank you for the feedback. It's my pleasure helping you.
