Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 as access point and USB3
Cecemel
I just bought this amazing router and was configuring it. Because I have a router from my service provider which is hard to switch off I'll use my netgear as access point and disabled the wireless from my provider. This is also the reason I bought it.
Everything works fine and fast but the USB3 readyshare is not working when my HDD drive is connected on the USB3 - port. On USB2 it works perfectly. When i use it as router and not as access point the USB3 is working fine. The problem is only there in AP mode.
Is it a known bug? Can it be fixed with new firmware? I would love to use the USB3-port as well because it is way faster and I use it as a NAS now for my HD movies to stream and copy to it (fast access needed).
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: Nighthawk R7000 as access point and USB3
Hi @Cecemel,
Welcome to Community!
I did try the configuration that you have and I was able to access both USBs connected on USB 2.0 and 3.0. The router was set as router and AP mode also. Have you performed factory reset or reload the firmware?
JamesGL
Community Team
Message 2 of 5
All Replies
JamesGL
Master
Hi @Cecemel,
JamesGL
Community Team
Message 2 of 5
mondenath
Prodigy
Message 3 of 5
Cecemel
Reuploading the firmware seems to solve the problem. Strange cause it is the same firmware as before.
I did not try the limited release firmware, it probably works also but I prefer the latest stable versions and not the beta ones.
Thanks for the help guys!
Message 4 of 5
rpoffen
Virtuoso
Seems a number of problems have been fixed for some people simply by reloading the FW, especially when performing a factory reset to defaults in the process (which is highly recommended when load FW).
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4132 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
