- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 does readycloud override readyshare?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just updated the firmware on my Nighthawk R7000 and decided to try the ReadyCloud option. We have used ReadyShare to access drives on our local network for years. However, once I set up ReadyCloud I could see the drive on my local network but the files do not show up. Is there a way to use both? I would like the ReadyCloud access for times I am not at home, but it is way too slow for regular use. Plus we have a Sonos that needs to access music from the ReadyShare drive.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @skdmark
Welcome to the community!
I have no problems accessing ReadyCloud and local access at the same time.
After firmware update did you factory reset the router? If you have not, kindly do so.
Once done, reconfigure the router just like how it was then verify if you can access it both.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @skdmark
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 does readycloud override readyshare?
Are you on Windows 10?
Do you have a CERTIFICATE for READYSHARE (you need one to access the share). If not go into user account in control panel, select manage your credentials this will open 2 options web credentials and windows credentials. Use windows credentials and add a new windows credential. Enter the location of the drive \\readyshare on the first line, windows user name in the second line and windows password in the third line. Should fix the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
