- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Nighthawk R7000 needs frequent reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 needs frequent reboots
@Jmadsen1977 wrote:
Mine keeps needing to be rebooted how hard is it to reset and go back to .42 version
Your what?
Your footer says " A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0".
Whatever you own, the manual ios a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Check the section in the manual on updating the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Running: V1.0.11.116_10.2.100
First, Sorry that this got to long. Please feel free to ignore and not read the whole thing.
I just wanted to relay my experience and how I have the router behaving very well now.
________________________________________________________________________
So I have been plagued with this stupid problem to the point of where I started to look for a different router.
But I'm holding off because I seem to have the router cooperating a lot more by doing a couple of things every day or two, that seem to keep it operating just fine now.
I haven't HAD TO reboot it in a couple of weeks or so! THAT'S PROGRESS!
So first, let me say, I think that ONE of the major problems with this router and its firmware versions, is that it does not handle massive traffic very well, EVEN THOUGHT IT'S A 'GAMING" router.
For my gaming server (which I no longer run or bother with), I had a bunch of ports forwarded to my server's static IP.
Being that these particular ports are well known for the environment I was running, there were constant attacks by :
Russia
China
and a few other countries where reporting bad actors was useless.
At one point, so that I wouldn't have to totally remove all the redirects, I just put in a fake IP that went no where on my network, so that any attacks to any of those port ranges would just go to that fake IP.
I also set up huge ranges to redirect attacks to there as well...
THAT WAS A MISTAKE!!!! That's because the router would STILL try to process the requests rather than just ignoring them.
I would notice my entire network starting to grind to a halt , so I'd check the logs and see hundreds of attacks, trying to get into my server. From Remote Desktop attempts to DoS attacks to port hammering, etc.
I'd have to reboot my router and the modem that connects me to my ISP.
Doing so would get me a new external IP as well as clear the cache in the router.
I would also clear the logs, apply and refresh to clean that up.
Sometimes, I couldn't even log into the router and I would have to power cycle it.
I still have some ports open for my security cameras so that I can access away from home.
But with that, I still had the router choke up every couple of days.
I finally decided to REMOVE ALL PORT FORWARDING except for my cameras. Those are vital.
Well that settled things down A LOT!
However, then I would see those same countries trying to access my cameras.
So for those, I tightened up their passwords. At least it won't be easy for those BOZOS to monitor my cams.
But still, the router was not stable. Sure, it was a lot more stable, but I still had to reboot every few days!
To troubleshoot this problem, I have a Command Prompt constantly pinning google.com -t.
When the router would start to get wonky, I'd see packets dropping from the ping.... INTERESTING.
Sure enough, in the logs, I would see attacks, including still, DoS attacks.
But something still didn't seem right.
So then, I added another command prompt window and constantly piinged the router's internal IP.
I wanted to see if pinging outside my network to the internet would fail, but internal pinging was ok.
Sometimes, this was the case ,but other times, more often, when one would start dropping packets, so would the other! HMMMMM
So then, I powered up my laboratory computer, which sits right beside the router and is wired directly into it. This computer does NOT go through anything else, no switches, nothing.
I also ran a command prompt, pinging the router as well.
Now, with 3 pings being monitored, I could get a better visual on where the breakdown is happening.
So now here is where I found what is in fact one of the biggest problems with this dammed router.
THE LOGS! Yes! THE FREAK'N LOGS!
What I discovered that as the log file increased in size, is when the router would start to get wonky!
I could see dropped packets on the external ping, then drops on this machine that pings the router (but it goes through switches). But sometimes, the Lab computer wasn't seeing drops!
But then, I'd start seeing drops on the connected Lab computer.
I started monitoring the logs closer but nothing unexpected was seen.
I did notice, however, that the drops were right around the time that the attackers were trying to get connected to the ports that I did have open.
But at other times, even with that, there was no issues.
I got into the habit of clearing the logs so I would get a clear picture each time.
It's then that I noticed, when I cleared the logs, within seconds, the dropping of packets stopped and the router settled back down!
I've seen this kind of file corruption in older software, but I would have thought that in 2020/2021 there would be much better routines to keep caching in check.
So, very long story short,
- remove any port forwarding that you do not NEED
- do not set up huge ranges of ports to forward to a fake IP (if you don't forward ports, the router will just ignore requests to ports not listed)
- clear the log daily (at least to confirm if this solves the problem).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
(I always run wireless, but changed this also.) So far, for the last 12 hours, I’m still up and running!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you all for your expertise in this matter. The router seems to be sufficient for our family when it isn’t offline.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you keep having to reboot your router definitely follow the instructions for installing the older firmware. Also, I am not that techy and the directions in this thread were complete and accurate. Thanks again all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having this issue, running firmware V1.0.11.116
I can see there's a V1.0.11.128 available
Should I bother with it or just go directly to .42?
Or just install Tomato and be done with it...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting, I've followed your advice on log settings and will see how that goes.
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been a few days now with logs disabled and no further problems, seems to be that this was my issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is excellent! We may be proving what I've found, which if Netgear were to pay attention, might look at their code for the logging routines. While I'm no longer a programmer for any company (I just write my own software for my own uses) my suspicion here is that there's a major memory leak and/or issues with coding for the caching routines.
What seems to be consistent is after a while of the logs building, is when the router "freezes" up. It's like there's no more memory space for other routines, like... ROUTING, to use.
Time will tell.
May I ask, did you put a small fan on the rear, right corner over the vents there, blowing down to the inside of the router?
Since I've added that, the router is running nice and cool now.
I also added a fan to my WD MyCloud NAS box. I was surprised that it doesn't have a fan, yet, it's firmware is "fan aware!" GO FIGURE!
What I mean is, is that when I check the stats, there's a "fan indicator" saying that the fan is NOT spinning. But there is no fan inside nor room for one... I find that interesting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't add a fan, didn't have one to hand.
I do have the router mounted vertically with good all around air circulation in a realatively cool room though.
Perhaps the overheating issue was caused by the logging issue so solving that dodged the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It sounds like you might be ok with heat. You can just touch the top of the case to feel if the plastic is hot or not. I do think that the over logging contributed to the freeze up problem. After I did the log mods, the unit ran find without failure for a long time. Where I got concerned about heat, was when I enabled ReadyShare and connected a 2TB drive to the router. This was before I bought the WD NAS unit. I wanted to offload my projects drive from my main laptop (shared drive) and have it as a stand-alone. What happened was, when I was transferring the data from the main computer up to the drive attached to the router, the router got hot due to high traffic and yup, it froze u again and when I touched it, it was HOT. Thus, the fan. However, I removed ReadyShare and just bought a dual-bay NAS and that it working just fine. I did put a fan on the NAS as well as the router. Keeping things cool does help electronics to not fail so soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have solved this problem!!! I simply took my Nighthawk router and threw it in the garbage and then connected to an old Linksys router that I found and the problem is solved! Have been up and running on the Linksys router for a few weeks now with no issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is why forums aren't helpful with responses like these. Yet I am running the same Nighthawk routers for 30 office people at my company and my home with no problems. I have thrown out plenty of Linksys routers in my time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Users should also read, review and check out what others have done as well:
- « Previous
- Next »
