Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 not reading my bandwidth properly
suewald
Follower
App version: 2.10.6.1635
Firmware version: v1.0.9.88_10.2.88
OS: Windows 10
ISP: Spectrum
Bandwidth: 400 mbps
Why is my router only picking up 200 mbps when I do a speed test on it?
suewald
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
sktn77a
Virtuoso
Re: Nighthawk R7000 not reading my bandwidth properly
I have a similar issue with my R7000.  Google fiber, 900+ up and down connected directly to computer but only 350-400 when connected via router (ethernet, not wifi).  I'm using an older firmware version (v1.0.9.42) and am considering updating to the latest firmware but I don't think that will change anything.
Message 2 of 3
Guru
@suewald
1. that's not the latest version of firmware.
2. whatt modem are you using?
3. how are you testing speeds? using the nighthawk app? using  the speedtest app? over wireless? over a wired connection?
4. do you have qos, access control, parental controls, or traffic monitoring enabled?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 358 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
