Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 - power usage when WIFI turned off
rree_nl
Follower
Hi,
I was searching for the power usage of the R7000. I found an article (dutch) where they tested the power usage: 7,3W / 7,8W with 3 devices attached.
https://nl.hardware.info/reviews/5170/14/netgear-r7000-nighthawk-ac1900-review-nieuwe-eindbaas-testr...
Can't find the power usage from the R700 on this site. Does anyone know if the power usage drops if I turn of the WIFI?
I have too many WIFI signals and I want to change my network setup. I need this router to bring the netwerk signal to my attic (concrete walls don't work too good with WIFI signal). Therefore I am thinking to turn off the WIFI signal of this device, or replce this device with an simple bridge if that power usage is less.
Best regards Roel.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Accepted Solutions
JamesGL
Master
Re: Nighthawk R7000 - power usage when WIFI turned off
Hi rree_nl,
Disabling the WiFi radio reduces the power consumption.
Message 2 of 2
All Replies
JamesGL
Master
Hi rree_nl,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1551 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
