Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 slow download speeds
Missy10_
Tutor
I'm getting slow speed through a wired connection. It's slow on a Xbox one. As well as a lap top. I've tried different cables as well. Wi-Fi is pretty fast. Tried resetting the router butg nothing seems to correct the problem. Any suggestion?
Message 1 of 7
Accepted Solutions
Missy10_
Tutor
Re: Nighthawk R7000 slow download speeds
Looks like disabling QOS worked. Don't understand that a feature that's supposed to help does the complete opposite. Thanks for the help.
Message 4 of 7
All Replies
shamarin
Virtuoso
Try to disable QoS.
Message 2 of 7
IrvSp
Master
Would like more information please:
  • What is the ISP speed you should be getting?
  • What is the wired speed you are getting?
  • What is the band that the wireless speed it on?
  • Are you getting the wireless from the R7000 or your ISP's modem (which might provide wireless)?
  • Can you open the router's web page in a browser and select the ADVANCED tab on the top. Then on the INTERNET PORT box select SHOW STATISTICS. What do you see for PORTS STATUS for WAN and LAN 1 - 4? Is it 1000M/Full? Yes, some will show LINK DOWN if there is NOT a cable in the socket for that LAN port.
  • What Router Flash are you using?
Message 3 of 7
Missy10_
Tutor
Message 4 of 7
shamarin
Virtuoso
To help - not so, it depends on what speed do you have from you ISP. If this speed is 100 Mbit or more QoS will not improve you speed.
Message 5 of 7
Missy10_
Tutor
I get 60mb down and 4or 5 up.Either way it corrected the problem. Thanks again nether community.
Message 6 of 7
jazzchamp
Tutor
I also thank you for this!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 7651 views
  • 5 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
