- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 stopped working after 4 months
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 stopped working after 4 months
@Bemanmac wrote:
I went through all of the troubleshooting steps in the manual....
Did that include a "factory reset"?
They'll ask you to do that before you can begin the warranty process.
Oh, and is the firmware up to date?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
contact support for a exchange.....mine is over 3 years old and working fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
" My old modem lasted over 4 years, this is simply unacceptable." somewhat I can understand but if you compare to ISP crap it's only every year with less more features and capabilities.
4 y/o stuff in this world is obsolete!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it still works and does what you want, there is no reason to stay on the upgrade treadmill.
@aalexandrebeta wrote:it's only every year with less more features and capabilities.
This is meaningless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please share the fix..Taking to son is No Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the Nighthawk Routers, if you do a factory reset more than just once in say, less than an hour, it confuses the router - essentially, it is trying to reset itself and in the middle of the reset, you interrupt the process with another factory reset and "confuse" the OS and once the router stops working - no matter what you try (ie. re-login, changing browser settings - pretty much anything in the troubleshooting discussions, it won't work. I cannot tell you the intricate details of the exact steps he took ( I just happen to be fortunate to have him, perhaps there is a local "techie" that doesn't charge too much that could get the same results), but when I walked in his office he had the Genie page up and all was well. He uses only Netgear wireless equipment in his entire school system, he says they are, in hs experience the most consistantly dependable. The biggest take-away is that if you push that factory reset button, give the router a good hour (err on the side of caution) before you attempt any "fixes". This was "my bad", because when a person gets frustrated, you just start pressing buttons (common, according to son) So patience with the factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I have found is after a reset to defaults the PC needs to be rebooted to connect to it before you login into router setup. I will say this was not always the case and changed about 2 years.
I finally dumped NG FW and wished I had years ago.
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem!!! I am angry that after only 4 months, this unit stopped working out of the blue. I was watching the Olympics - suddenly nothing. I missed the closing ceremonies too. I called Netgear and they wanted $50 to answer my question!!! I had never called their customer service and was appalled they wanted so much money to find out why their product stopped working after owning it for such a short time. Customers do not get even 1 service call???????? I will throw this unit in the trash and NEVER EVER BUY NETGEAR MERCHANDISE AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dpou wrote:I called Netgear and they wanted $50 to answer my question!!!
That's the brainless and scripted response from people who don't know what they are doing. It upsets the Netgear people here as much as it upsets customers.
If you have a warranty issue, don't ring the support online. (I know, that sounds mad, but this is Netgear.) Go visit the warranty bit of the website. Or ask to be put through to the warranty people.
I assume that you are in the USA. Unfortunately, consumer protection is not as good there as it is here in Europe, for example, where 4 months would be seen as a joke. In the EU four years would be more like it. But you should still have at least a year's warranty support.
First, though, ask around here for help. Someone may be able to help you to rescue your R7000. For a start, have you reset the thing to its factory defaults?
