Orbi WiFi 7 RBE973
Reply
Nighthawk R7000 wireless option unavailable
Sbruner
I have a R7000 I've used for a while with no issues. This evening the wireless stopped working. The checkbox to "enable wireless router radio" is grayed out and unavailable.
Checking the logs I noticed a firmwear upgrade this afternoon to v1.0.4.30_1.1.67.
Any suggestions would be appreciated.
Message 1 of 7
Accepted Solutions
Sbruner
Re: Nighthawk R7000 wireless option unavailable
A reset worked. Thanks so much
Message 3 of 7
All Replies
Start by resetting the router, loading defaults.  Save and restart.  If this doesn't haelp, I would manually reflash, load setup defaults, save and restart.  Let us know how you make out.
Message 2 of 7
Sbruner
Message 3 of 7
aVIP2u
Initiate
I have the same problem.  The recent firmware update shut down the wireless radio and it is greyed out.
I tried
(1) reboot from within the router settings/admin page = no results
(2) unplug, wait, plug back in = no results
I have the follwoing:
Hardware VersionR7000
Firmware VersionV1.0.4.30_1.1.67
GUI Language VersionV1.0.4.30_2.1.38.1
Message 4 of 7
aVIP2u
Initiate
Replying to my own post - -
Searching elsewhere on the internet, I found that, there are two buttons on the top of the router (right side).  They look like the LED's unless you feel them with your finger.  The second one from the right is the WiFi "on/off" button.  You have to press & hold it for 2 seconds. In my case, it looked like nothing happened.  I then had to go back into Settings and the little check boxes were no longer greyed out.  Click the box(es), click "Apply", then it worked.
P.S.  my wife had set something down on top of the router, inadvertently pressing the button.  Now I have a sign on it not to do that.
Message 5 of 7
Aseret
THANK YOU SO MUCH. Didnt know it was a problem with just one click to solve
Message 6 of 7
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 12886 views
  • 7 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
