Orbi WiFi 7 RBE973
Reply
Nighthawk R7000
TWP73
Follower
Nighthawk R7000
I have tried everything I have found or been told to try so I can log in to my router.  Nothing works, not Routerlogin.net or com, nor does the IP address work.  I am out of ideas.  It will typically say page does not exist for the Routerlogin,net or .com.  Does any one have any ideas.  I have tried to use my phone, my laptop, with and without an ethernet cable.  Please help
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Accepted Solutions
Guru
Re: Nighthawk R7000
What are the led's doing?
What modem are you connecting to?
Unhook everything from it. Factory reset it by pushing and holding reset for 7-10 seconds until the lights change. Give it time to fully reboot afterwards. Then hook a single pc to it via ethernet cable. Are you able to access it? try the routerlogin.net   and try 192.168.1.1 (should be default ip address)
Message 2 of 2
All Replies
Guru
Re: Nighthawk R7000
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1177 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
