Orbi WiFi 7 RBE973
Reply
Nighthawk R7000p
dberger8811
Tutor
Nighthawk R7000p
If I do a factory reset on a Nighthawk R7000p router so that I can give the router to a friend, does the name like Orbi 42 change to connect to WiFi or stay the same.? I know the login and password change back to admin and password?
Message 1 of 3
Accepted Solutions
Guru
Re: Nighthawk R7000p
It goes back to whatever the default ssid/password were that was on the device.
We don't know exactly which it is but it should be on a sticker on the device.
Message 2 of 3
All Replies
Guru
Message 2 of 3
dberger8811
Tutor
Thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 852 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
