Reply
Nighthawk R7100LG Drops Connection
stakadush
Hello,
I'm having serious issues with this router / modem. It keeps disconnecting from the Internet at least 2 times a day. Wifi works but not Internet. Also sometimes when I try to access the admin panel I get an updating settings screen with a progress bar. The only way I can get the Internet back is by restarting the router. I'm on the latest firmware V1.0.0.48_1.0.6.
I'm about to send it back to Amazon but wanted to see if you have a solution before I do. Hope you do cause I like this router but it's impossible with all these disconnects.
Thank you Smiley Happy
Model: R7100LG|Nighthawk 4G LTE Modem Router
Message 1 of 9
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk R7100LG Drops Connection
Have you tried to factory reset the unit?
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
DarrenM
Message 2 of 9
stakadush
Hey Darren,
Unfortunately it doesn't work. I had to reset it twice for it to work and then it started connecting but this morning I woke up to it not working again, and after 2 reboots (one through the admin UI and one physical) it still doesn't connect ...
I have only 1 week left on my return voucher to Amazon so hopefully you can help me solve this before, otherwise I'll have to send it back, it's too expensive for a machine I have to reboot at least once a day.
Message 3 of 9
DarrenM
Are you using the LTE as a provider or a cable/DSL line?
DarrenM
Message 4 of 9
stakadush
I'm using LTE (3G/4G). But I gave up, I'm sending it back today.
Real shame, I was hoping this router would be better than the one provided by my provider but it just gave me headaches this last month. Constant disconnections, just can't work like this.
Thanks Smiley Happy
Message 5 of 9
BearSWE
Same issue here.....
V1.0.0.46_1.0.6  Firmware
my Nighthawk MR1100 works fine but i needed a more permanent solution and switch so i bought a R7100LG but the piece of ###*(& loses LTE connection randomly and needs a restart.   Any firmware fix coming soon or is the only solution to returen it and buy another brand Smiley Sad
Message 6 of 9
DarrenM
Hello BearSWE
What mobile carrier are you using? how often is the router losing connection?
DarrenM
Message 7 of 9
BearSWE
Tryed diffrent carriers.. but using Telia LTE as preffered.
Firmware .42 works. .46 and .48 dont.
But with .42 i loses remoteaccess with genie and the trafficcounter dosent seem to work.
Still waiting for a fix ........
Message 8 of 9
Elnero
Guide
Same problem here. Firmware 10048. Sometimes drops till 4 times in an hour. Also drops during the night, without traffic. Sometimes recover automaticly after 2-3 minutes till half an hour, most of the time have to restart with Genie , exeptionaly had to reset/reiniciate and even restore factory manualy. Also downloaded and installed latest firmware 3 times. Am following it by log/ hour/email
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1211 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
