Reply
Nighthawk R7800 Router Firmware Version V1.0.2.68 update issue
brucegeorge81
I am currently operating on Firmware Version V1.0.2.62. When I updated to Firmware Version V1.0.2.68 my router would not connect to the internet. I reverted back to .62 and everything worked again. I then gave .68 another try and the same thing, no internet. I am back to .62 with no issues. Anyone have the same issue when upgrading to .68? Please assist.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
katesmith1304
Re: Nighthawk R7800 Router Firmware Version V1.0.2.68 update issue
hi i am facing the same issue. any sort of help will be highly appreciated !!
Model: Dual Band
Message 2 of 4
brucegeorge81
Hello. My problem has been resolved thanks to receiving assistance from a Netgear Tech. I was allowing the router to dowload the firmware update. It must have been corrupted. I went to the site and downloaded it and it now works. As a side note, check the lights on your router after you update the firmware. It they are amber/orange you may have some other issues and you may need to download from teh site as I did. Other than that you may need to contact Netgear. I hope this helps.
Message 3 of 4
katesmith1304
My problem has been resolved tooo..!!!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 465 views
  • 0 kudos
  • 2 in conversation
Announcements
