Reply
Nighthawk R7800 cable to wifi and viceversa extremely slow switching
rehoutm
Star
When trying to get some data between a wired and wifi devices, it is extremely slow (like 1KB/s slow, i.e. PLEX client doesn't even load home page).
Problem occurs in both directions - server wired client wifi, as well as server wifi, client wired.
When communicating wifi-wifi, everything is fine on both client and server.
Also WAN speed is fine on both wired and wifi, >100MB/s
Firmware version V1.0.2.28, every QOS feature is disabled (access control, QOS, dynamic QOS, WMM, ...)
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 7
rehoutm
Star
Re: Nighthawk R7800 cable to wifi and viceversa extremely slow switching
I tried a few steps to narrow down the problem, and I think I found out what is the cause, but don't know what to do about it.
My ISP is a PPOE fiber broadband with IPTV via VLAN tagging. Internet on VLAN 848 and IPTV on VLAN 835.
Steps I did:
1/ factory reset (no PPOE, no VLANS) - now everything works fine, wifi-cable communication fast as it should be
2/ setup VLAN (no PPOE, just VLANS) - everything is still fine
3/ setup PPOE (PPOE + VLANS) - now the problem occurs - wifi-cable communcation crippled to nearly zero
Message 2 of 7
TheEther
Guru
That sounds like something that Netgear Engineering needs to look at.
Cc: @ElaineM
Message 3 of 7
rehoutm
Star
Just bumping, still no success.
I mentioned the problem is kindof not just about switching speed, it is also about broadcasting.
E.g. - I can ping devices from wifi to cable and viceversa, but any auto-discovery capabilities do not work.
Message 4 of 7
rehoutm
Star
Bump 😞
Message 5 of 7
ElaineM
NETGEAR Employee Retired
@rehoutm Is the router registered? I would strongly suggest that to submit a case through my.netgear.com
ElaineM
NETGEAR Community Team
Message 6 of 7
rehoutm
Star
I just registered it and submitted an email case.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3216 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
