Reply
Nighthawk R7900P will not stay connected to the internet.
Bob_1956
My router loses the Internet connection at lease once a day and must be re-booted. The router is connected to a Cable modem. Firmware V1.3.0.10, Windows 10
Model: R7900P|Nighthawk X6S Smart WiFi Router with MU-MIMO
Message 1 of 4
Re: Nighthawk R7900P will not stay connected to the internet.
A couple of questions, what is the cable modem? (Is it a modem/router?)
What version of firmware do you have on the R7900P?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
Bob_1956
Firmware V1.3.0.10, It is a Arris Modum & Router.
Message 3 of 4
You have the latest firmware.
As you have a modem/router, you have the possibility of conflicts between your Netgear router and your modem/router. In that case you should either work out how to tell your modem/router to work in modem only (bridge) mode or put your Netgear router into access point (AP) mode.
You will have to check the respective manuals for advice on how to do this.
There is a manual for the R7900P at the end of this link:
>>>> Nighthawk X6S R7900P | AC3000 Tri Band WiFi Router | NETGEAR Support <<<<
Just another user.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 529 views
  • 0 kudos
  • 2 in conversation
Announcements
