Reply
Nighthawk R8000 100mb/sec cap
fLAYOLOGIST
Follower
All cables are Cat6 (modem > router) and (router > PC)
Direct PC to Cable Modem gets 300mb/sec on speed test (which is the speed i have from cable provider)
Ethernet Status in device Manager shows 1.0 Gbps connection
I have QoS Disabled in router
So from the testing I have done I have the full speed i pay for from my cable provider when i connect my PC directly to the modem. This would logically exclude cables, modem, and ethernet adap[ter, PC from the list of possibly faulty equipment.
The problem is that over a wired connection from my PC to the nighthawk R8000 the maximum speed I can get is 102mb/sec avg.
Anyone have any ideas before i RMA this router?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk R8000 100mb/sec cap
Did you ever figure this out or RMA the unit?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
