Reply
Highlighted
Nighthawk R8000/AC3200 wired connection is half the speed than connecting directly to CM1000 modem?
Like the title says, direct connection to the netgear CM1000 modem on my win10 machine, I get ~940Mbps but when I connect through the router, I get ~470Mbps.
I have seen a few threads about this and tried to check them out with no luck:
  • checked the cables direct to modem and through router and both work fine.
  • someone mentioned MAC cloning and I am not sure what this is but I have not messed with my MAC address at all. Xfinity has my modem MAC address registered so I was assuming it shouldn't be a problem.
  • Someone else mentioned accidentally ticking off a traffic meter but mine is off.
  • I have the latest firmware.
Looking for other suggestions to try out.
Thanks
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Highlighted
Re: Nighthawk R8000/AC3200 wired connection is half the speed than connecting directly to CM1000 mod
Turn off QoS.
There is a manual for your device somewhere at the end of this link:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
See page 42.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 335 views
  • 0 kudos
  • 2 in conversation
Announcements
