- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R8000 WR cannot log into router over wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having this issue on two devices since I updated the firmware 1/12/2021: Windows 10 desktop and LG 8x Android cell phone.
Both are telling me that I am not connected to the router wifi. As I am connected to the R8000 wifi and have access to the internet.
I cannot ping 192.168.1.1 or access using routerlogin.net. I've reset the router, holding the reset button for 7 seconds and did the hold the reset button for 30 seconds, turn off the unit holding the reser button 30 seconds, and power the unit back up holding the reset button for 30 seconds. Nothing worked.
All my home devices are connected and worling. Just no access to the router.
I did just remove McAfee Virus software from my desktop but it wasn;t on my cell phone.
Please someone who has the answer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R8000 WR cannot log into router over wifi.
What firmware version did you install?
What modem/gateway is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not write down the firmware version. It's an Arris DG3270 from WOW.
What I don't understand is that it does not recognize that I am on the Nighthawk wireless routers WIFI. Keeps asking me to connect to the routers WIFI???????
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am seeing similar issue on a 7960P
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Arris DG3270 is a modem/router combo device. It isn't just a modem. Unless you have it in bridged/modem only mode, it creates a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Options? (only use 1)
1. put the arris in modem only mode.
2. put the netgears IP address into the arris's DMZ
3. Put the netgear in AP (access point) mode. This disables the routing functions and leaves the arris in control of those. You can either disable the wireless on the arris to reduce interference or just ensure its on a seperate channel from the netgear.
it could be why you can't access the router at the defaults ip address, it might have changed when it detected another router on the network/using that ip address.
Easy check. disconnect the netgear from the arris and reboot the netgear. Then connect a pc/laptop to it and open a command prompt. Type ipconfig. The default gateway is going to be the netgears IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ajbernard You have a different router entirely. Please start your own thread instead of jumping on someone elses and we'd be hapy to help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Already started - but it seems to be a common thread across many NetGear devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Because too many people turn up without understanding what they have on their networks.
Unfortunately, there is no single solution.
