Reply
Highlighted
Follower
Nighthawk R8000 WiFi issue
Hello.,
I’ve had this router for about a month. I have ATT 1000 service , and the nighthawk is set up for wireless pass through to manage my WLAN. It has worked fine for about a month, however as of yesterday the speeds have dropped precipitously (~250 MB to sub 40) with drops/lapses in wireless coverage. I can hardly load any websites without the connection timing out.
My PC connected to the gateway directly gets ~430 down.
I have firmware 1.4.1.30
I have QOS turned off (tried cycling, didn’t help)
I’ve changed the cat 6 cable connecting the router to the ATT gateway.
I’ve reset the router to factory.
Any advice would be appreciated, I can’t figure out why I’m getting such bad performance for no apparent reason.
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 2
Highlighted
Master
Re: Nighthawk R8000 WiFi issue
Looks like you have done about everything other then return and get a different router from a different vendor.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 236 views
  • 0 kudos
  • 2 in conversation
Announcements
