Reply
Nighthawk R8000 after the firmware update nothing worked anymore
Ngtr
Follower
I own the Nighthawk R8000. I wanted to download the firmware update V1.0.4.28 to my router. Actually it should have been finished long ago. The Power-Led now flashed white. Since then the Wlan does not work anymore. I tried to reset the router several times and then load either V1.0.4.28 or V1.0.4.28 onto the router, unsuccessfully. I followed these instructions among other things "https://kb.netgear.com/de/31504/Neuinstallation-der-Router-Firmware-ohne-das-Verwenden-des-CD-Recove...".
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
antinode
Guru
Re: Nighthawk R8000 after the firmware update nothing worked anymore
> [...] The Power-Led now flashed white. [...]
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
   You don't need any third-party TFTP client programs for this.
> unsuccessfully. I followed these instructions among other things [...]
   Too vague.  The TFTP recovery scheme has many steps, with many
user-supplied data.  As usual, showing actual actions (commands)
with their actual results (error messages, LED indicators, ...) can be
more helpful than vague descriptions or interpretations.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 247 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
