- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R8000 to Virgin Media Super Hub 2 Connection problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R8000 will not connect to the virgin media super hub at 1.0 Gbps. I have a 150 meg line and through the R8000 I only get 96 Mbps.
My local area network is set to the following:
Speed = 1.0 Gbps.
I have performed factory default settings and it has not cured the problem.
If I connect the VM super hub 2 directly to my PC I get 158.2 Mbps when the local area newtwork speed is 1.0 Gbps
I am running Windows 10
When connected to the VM hub via Wifi I get 157 Mbps on the % GHz line.
Any sugestions on how to get this sorted would be very usfulll
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R8000 to Virgin Media Super Hub 2 Connection problem.
You may have a negotiation issue between the R8000 and the Super Hub. First try replacing the cable between hub and R8000 with at least a CAT5e cable. (Cat6 better)\ and retest..
- Mark as New
- Bookmark
- Subscribe
- Permalink
The cable is a cat 6 and I have tested it with a network cable tester. The same cable is used to connect the VM modem to the R8000 and the PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
if you have a dumb 1 gig switch, use it to plug the router and VM hub into it. Ther's an obvious negotiation between both devices..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cannot answer that as I dont know where that page is on the R8000 system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found some information about a connection and it is DHCP if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also the link light on the VM hub is yellow (100 Mbps).
From what the VM help line said I think the green light should be on for 1.0 Gbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
But if the VM hub is indicating the link speed is 100 Mbps, then I expect the R8000 will say the same thing. Either your cable is bad or, perhaps, the VM hub is forcing the link speed to 100 Mbps. Check if there is a speed setting on the VM hub.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK I nipped out today and got a Thunderbolt to Gigabit Ethernet adapter for my MacBook Air so I can test the VM router cables and so on.
First of all I tried every Ethernet port on the VM router and got 1 Gbps (150 Mbps).
Second I tested the cable to the R8000 router and got 1 Gbps (150 Mbps).
I have now found the information you wanted on the R8000:
WAN = 100M/Full
LAN 1 = 1000M/Full
LAN 2 = Link Down (Nothing connected).
LAN 3 = 100M/Full
LAN 4 = 1000M/Full
2.4G WLAN b/g/n = 600M
5G WLAN a/n/ac = 1300M
5G WLAN 2 a/n/ac = 1300M
Nighthawk Firmware Version is V1.0.3.4_1.1.2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I could find no speed setting on the VM hub.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I suggested on the first page... If you have a dumb 1 gig switch, use it to plug the router and VM hub into it. There's an obvious negotiation between both devices..
Then check your WAN connection. Even if you can borrow one to test with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will see if I can borrow one during the week.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will try that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have plugged the Mac into the WAN port and I get 1000/Full.
It still goes back to 100/Full when I put the VM hub in the WAN port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are your Ethernet cables straight-through or crossover? It shouldn't matter, but try using the other type than you are currently using between the R8000 WAN port and VM hub. If that still doesn't help, then use the advice of @netwrks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My cable is a straight through cat 6. I tried a crossover cat 5E cable and it made no difference.
I got a Netgear ProSafe 5-Port Gigabit Desktop switch and connected it to the VM modem and then the R8000 to the switch.
The results I got are below:
WAN = 1000M/Full
LAN 1 = 1000M/Full
LAN 2 = Link Down
LAN 3 = 100M/Full
LAN 4 = 1000M/Full
I will now look at the @netwrks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I had a 1000m connection but I was only getting 126 Mbps (Not 1507 Mbps).
This bugged me so I tested the cable again and found no problems.
Cut the end off at my computer end. Fitted a new RJ45, tested it and tried it in the R8000.
Fixed the problem now getting 157 Mbps. Although I tested the cable several times and found no problems it was worth replacing the RJ45.
I have now ordered a new cable Cat6E and will use that in future.
Many thanks and I think it was worth it as I learnt a few things as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to hear that your problem has been resolved. Note, technically there is no such thing as Cat 6E. There's Cat 6 and Cat 6A. For short runs, like 10m or less, they are overkill. Cat 5E is perfectly suitable for 1 Gbps. But if you are determined to go better than 5E, then skip Cat 6 and go to Cat 6A. The latter is rated for 10 Gbps up to 100m.
Since you appear to be terminating your own cables, you should investigate whether you may need new tooling. I believe Cat 6A, especially shielded Cat 6A, requires different methods for termination.
- Mark as New
- Bookmark
- Subscribe
- Permalink
