- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R8000P no connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk was set as AP and worked without flaw for 8 months. Dropped and had to reconnect. The issue become more frequent. Now, it drops almost immediately. Upgraded firmware to the latest version. No change.
My router uses the domain 192.168.0.1. The IP on the device is 192.168.1.1 and you cannot change to add it with a static IP like192.168.0.3.
Looking for an answer since the device is not quite a year old.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R8000P no connectivity
> Nighthawk was set as AP [...]
How, exactly, was that done?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point".
> 192.168.1.1 [...]
What is your (unspecified) "My router"? How, exactly, is it
connected to your R8000P-as-WAP? (Hint: If a device has different types
of ports, then "connected to device" is not enough detail.)
What is your (unspecified) "the device"? Some client computer, or
what? How is it connected to what?
If devices which are connected directly to your (unspecified) "My
router" are on one IP subnet, and devices which are connected directly
to your R8000P-as-WAP are on a different IP subnet, then I suspect that
your R8000P-as-WAP is not configured as a WAP. (Or you have some other
router in there.)
> [...] and you cannot change to add it with a static IP
> like192.168.0.3.
What happens when you try?
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Either one should fix the address of a
device, but some implications are different.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is usually the default IP address on a modem/router.
This may have a few tips to follow up:
Re: Nighthawk AC1900. Unable to connect to router ... - NETGEAR Communities
