Orbi WiFi 7 RBE973
Reply
Nighthawk R8000P with Loss of Item connections
Rdp_75
Follower
I have been using a Nighthawk WiFi R8000P since I purchased it when available. The only problem that occurs is about connections that are not listed in the Attached Device list, or does not assign the IP Addresses from the LAN Setup list with data entered by me. These settings are crucial in my network. Current Problems that fail intermittently: !) Assignment of IP Address fails intermittently. 2) Cross reference from MAC address to IP address. 3) Sorting of Attachment List is not available. 4) Sorting of Setup List is not available. Are corrections available to resolve these problems? Thank you. Rdp_75
Message 1 of 2
Guru
Re: Nighthawk R8000P with Loss of Item connections
what firmware version are you on?
What modem/gateway is it connected to?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 310 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
