- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R8000p router keeps trying to update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware version are you on?
One thing, I'd recommend against updating using the app or over wireless. when we see corrupt firmware versions, its usually when done via the app or wireless. I'd do it over a hardwired connection for best results.
When the speeds slowed down, did you ever try a factory reset and reinstall? if there's issues after changing firmwares, thats one of the first things we recommend.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R8000p router keeps trying to update
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a known issue with firmware version 1.4.1.50. not being able to upgrade ... check the posts for the "story" ie "Netgear Nighthawk R8000P Firmware Update"
( I had similar and had to get the r8000p replaced, then ensured by manual upgrade that the replacement didnt "upgrade" to version 1.4.1.50.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the heads-up. I will check out the post.
