DonkeyJuicer's avatar
DonkeyJuicer
Follower
Mar 12, 2021
Nighthawk R8500 Port Forwarding not working
I tried my very hardest to forward my port, but it did not work. I've attempted to set a static IP address and then port forward again but it still didn't work. I've launched something to use the port, but when I use the port checker it says the connection is timed out no matter what I try. I beg of anyone reading this, please free me from my misery and fix this troublesome issue that has plagued me and my mind for hours. I can feel my sanity decreasing every second that I am left with this failure of mine, and I don't think I can last much longer. If no one helps me soon, I fear the worst may come.My port forward
  • > Nighthawk R8500 [...]
       Firmware version?  Connected to what?
    > [...] I tried [...] did not work [...] I've attempted [...] didn't
    > work [...]
       None of that is a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       I can't (yet) see your picture.  In-line images must be approved
    by a moderator before others can see them.  The time required varies.
    Attachments have no such limitation.  Of course, attachments have their
    own one-per-message limitation.
    > [...] I fear the worst may come.
       What could be worse that trying to guess what you did, and what
    happened when you did it, based on no useful information at all?
       Is there some actual problem which you are trying to solve using port
    forwarding?
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
  • michaelkenward's avatar
    michaelkenward
    So begin with a simple explanation of what you actually want to achieve.
    Like the points on a railway line, which are there to send a train to B rather than C, Port Forwarding is there so that you can make something happen.
    Has someone said to you that you need port forwarding to get a device or service to work? If so, what?
    You never know, someone may have been down that road before and can offer informed advice on port forwarding. Or they may have managed to do what you want in a completely different way.
