Reply
Nighthawk R8500 slow on Cox GigaBlast
abenji
Follower
Greetings,
I'm having issues with my router.    My information:
NightHawk R8000
FW : V1.0.4.18_10.1.49
Reset Router: Yes
My ISP : Cox - gigablast
Modem : N/A
Hardwire : Ethernet from router to computer (245Mbps down/ 906Mbps Up)
Qos : Disabled
Wifi : 5Ghz (channel: 44 / mode: up to 1300 Mbps)
Wifi : 5Ghz (channel: 153 / mode: up to 1300 Mbps)
Wifi : 2.4Ghz (channel: Auto / mode: uo to 600 Mbps)
Guest Wifi : 2.4Ghz (disable)
Guest Wifi : 5 Ghz (disable)
MAC Filtering was never turned on (access control is not checked).
Questions:
I would like to get the upload speed that I am paying for.    In addition, i downloaded the app netgear analytics i'm sitting approx 12 feet from the router and I'm barely above good.  Any help that someone can provide would be appricated?
thanks
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk R8500 slow on Cox GigaBlast
What modem do you have? if its a modem with a built in router do you have it bridged or set to modem only mode?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 531 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
