Orbi WiFi 7 RBE973
Reply
Nighthawk R9000 5GB SFP
RichJacot
I'm only seeing 10GB SFPs mentioned for the R9000.  Does anyone know if there are any 5GB SFPs what will work with the R9000?
Thank you!
Message 1 of 4
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk R9000 5GB SFP
Message 4 of 4
All Replies
Greetings,
Suggest you purchase a 10GB SPF+ cable.  It will operate at slower speeds if the device you are connecting it to is slower.
However, you are likely to see better performance using the R9000 in conjuction with another device also rated at 10GB SPF+ instead.
Message 2 of 4
RichJacot
Can someone tell me if this one will work for a 5GbE connection to my NAS from my R9000?
https://www.amazon.com/Mikrotik-S-RJ10-MikroTik/dp/B078SNK1MY
Other options for a 5Gb copper SFP for my Nighthawk?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 3 of 4
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1037 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
