Orbi WiFi 7 RBE973
Reply
Nighthawk R9000 Gaming
JustHereToLearn
Follower
New R900 installed and up and running.  What do I need to do to optimize for gaming.  Are there certain settings that will get a better frame rate, etc.?
Message 1 of 2
Guru
Re: Nighthawk R9000 Gaming
Not a ton.
1. make sure you're on the least congested wifi channel.
2. make sure the gaming device is on 5ghz.
3. for best speeds/lowest latency, a hardwired connection is best but not always feasible
4. Make sure you're not in a double nat (2 routers on the network in router mode, many isp supplied gateways have internal routers)
5. test your speeds to see if you're getting what you expect. gaming doesn't take a lot of bandwidth but it needs to be consistent.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 217 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
