- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX120V2 on "Router Firmware Version V1.2.3.28"log not recording date and time
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk RAX120V2 on "Router Firmware Version V1.2.3.28".
I have the logs emailed every hour, (the reason I have the logs sent to me every hour, is because DoS attacks, IP 179.x.x.x are causing my router to stop access to the internet and sometimes reboots because of the DoS attack (wish to learn how to stop these someday).
The logs from 10:00 - 11:00 and all logs after that does not show the date and time.
I went in the router to look at the logs, the date and time is missing in the logs on the device also.
Would appreciate this to be fixed ASAP please.
Is this something I can fix?
Examples from Email:
10-11 am
[DoS Attack: NULL Scan] from source: 81.70.198.235, port 51587 [DoS Attack: SYN/ACK Scan] from source: 168.119.232.76, port 443 [DoS Attack: SYN/ACK Scan] from source: 45.148.10.81, port 9627 [DoS Attack: ACK Scan] from source: 169.63.130.180, port 80 [DoS Attack: SYN/ACK Scan] from source: 135.125.190.157, port 443
9-10 am
As you can see the reason in this example,
[DoS Attack: ACK Scan] from source: 45.148.10.81, port 14777, Friday, May 20, 2022 09:54:52 [DoS Attack: SYN/ACK Scan] from source: 65.108.67.115, port 53, Friday, May 20, 2022 09:54:15 [DoS Attack: WinNuke Attack] from source: 211.142.106.146, port 53139, Friday, May 20, 2022 09:35:25 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31 [DoS Attack: SYN/ACK Scan] from source: 179.107.55.102, port 49728, Friday, May 20, 2022 09:22:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX120V2 on "Router Firmware Version V1.2.3.28"log not recording date and ti
Hey, I wish I could be of help but I have NULL attacks coming from the same address as well. Running nslookup says the address in in the UK however google reports it's in China.
