- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX80 WiFi Password Incorrect
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue w/ V1.0.1.40_1.0.22 as w/ the previous firmware. I'm using my own 2.4GHz and 5GHz passwords, not the factory defaults. Every so often I have to have re-apply my passwords as I lose the ability on both wireless networks to login. The only fix is to re-apply the passwords via a wired connection, states the same passwords though and shows they haven't changed? Still shows both networks broadcasting too, like it loses what the passwords I set both wireless networks to.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Stick to alphanumeric for passwords and you should not have issues. Yes I know the standard says some special characters also will work, but in my experience not all clients will accept them. So don't try to be cute with the passwords and life will be easier.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX80 WiFi Password Incorrect
Do you have any special characters in the passwords?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
