- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RS7000 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RS7000 issues
Your problem is the first symptom mine was having before the WIFI quit working. It works only via cable. Their experts will only fix it for a $50 to 80 fee (depending the representative you get). Ours was only 7 months old. Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only paid for service backed by Netgear comes through Gearhead.
There is no $80 option. If someone offered that it was probably one of the scam sites that people get suckered into when they call a number they find when they run a Google/Bing search for Netgear support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Bwgibs wrote:
I am having to reset my router daily because the internet stops working, I have had my internet provider at my house multiple times and they have ran new lines and new connections and the issue still exists. I reset the router and the internet works fine after the reset. Please help?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting. It can also cause the sort of symptom that you see.
For more detailed advice, we need a bit more detail that "the internet stops working".
What do the LEDs on the front look like when this happens? Is it the whole Internet? Just the wifi? Wired stuff?
And do you really reset (as in restore the factory settings) or just restart the router?
