× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 1 reply
  • 111 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Nighthawk Router Not Getting Correct Bandwidth
I have Arris modem wired to Nighthawk R7000p. Getting Correct speeds from modem when straight wired bypassing router. But when I check speed from router, I'm only getting approximately 9Mbps download and around 6Mbps upload (which is correct upload). Also tried three different network cables with same results. It was working fine all year until the other day. I have reset router to factory settings, QoS and all other settings are at default (mainly off). The router was purchased in January 2018.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 2
Highlighted
NETGEAR Moderator
Re: Nighthawk Router Not Getting Correct Bandwidth
try speed testing from speedtest.net on the web instead of the internal speed test.
DarrenM
Message 2 of 2
