Reply
Nighthawk Router wifi will not connect to internet when cat6 are in the ports
WIFIBG
I have comcast internet. Surfboard modem, nighthawk router. When the modem is connected to the router only wifi works corrcetly. If I try to connect and ethernet cord to any of the 4 ports on the back of the router, the wifi stops working. All the wifi devices remain connected (at least the iphones and ipads show they are still connected) but can't access any websites, thus not connected to the internet. Any suggestions on how to remedy this issue?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: Nighthawk Router wifi will not connect to internet when cat6 are in the ports
Hi WIFIBG,
Reset the router. Check as well the firmware version and make sure to update it.
Message 2 of 5
All Replies
JamesGL
Master
Hi WIFIBG,
Message 2 of 5
JamesGL
Master
Hi WIFIBG,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 5
WIFIBG
Thanks JamesGL that worked!
Message 4 of 5
JamesGL
Master
Hi WIFIBG,
Glad to know it works now.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3683 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
