Orbi WiFi 7 RBE973
Reply
Nighthawk Smart WiFi Router AC1750
Frustratedme1
Follower
My router isn't showing my vizeo TV in the list of connected devices, and I'm unable to figure out how to add it.
I think this may also be causing an issue that's blocking hulu. Prime and YouTube stream fine, it's only hulu. Hulu tecks are mystified, ISP says it's a hulu issue, and vice versa.
Hulu won't connect on my Samsung tablet either via service provider wifi, but will via a Hotspot from my phone.
Speeds test fine, been through allllll the trouble shooting numerous times....
Please help
Message 1 of 2
Guru
Re: Nighthawk Smart WiFi Router AC1750
What router do you have? AC1750 is a speed
what modem/gateway is it connected to?
What firmware is on the router?
Only hulu is having issues?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 258 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
