Reply
Nighthawk WiFi radio automatically turns off
InvalidValue
Follower
Hi,
My router's wifi radio sometime turns itself off once in a while (every two three days or so).
I've been turning it back on but just not sure why it keeps happening.
Any ideas?
Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Retired_Member
Not applicable
Re: Nighthawk WiFi radio automatically turns off
Factory default reset to be sure a user setting isn't causing it, also make sure the front WIFI button isn't being pushed. If same problem continues you may have a hardware problem, try updating or reinstalling the FW it may help.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1749 views
  • 0 kudos
  • 2 in conversation
Announcements
