Orbi WiFi 7 RBE973
Reply
Nighthawk X10 AD7200 r9000 60GHz 802.11ad WiFi Disable
Hankhalljr
Hello,
How do I enable the 60GHz 802.11ad WiFi? Router Firmware Version V1.0.2.32. When I login to the router, wireless settings is disable (red X). Please help/advise.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 8
Accepted Solutions
Hankhalljr
Re: Nighthawk X10 AD7200 r9000 60GHz 802.11ad WiFi Disable
Problem resolved, I was successfully able to disable and enable 802.11ad WiFi.
Message 4 of 8
All Replies
JamesGL
Master
Hi Hankhalljr,
Check wireless settings under advanced tab. Make sure "Enable wireless router radio" is checked.
Message 2 of 8
JamesGL
Master
Hi Hankhalljr,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 8
Hankhalljr
Message 4 of 8
JamesGL
Master
Hi Hankhalljr,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 5 of 8
Adewale
Luminary
was looking forward to finding devices that can use the 60Ghz last year. here we are and i still don't know of any device with 802.11ad capability
Does anyone know?
Message 6 of 8
JamesGL
Master
Hi Adewale,
Check with Acer brand for laptops that support 60Ghz.
https://kb.netgear.com/31305/What-devices-support-11ad
Message 7 of 8
Adewale
Luminary
yeah, really sad...just annoyed i paid a premium for this router because of the feature
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 6659 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
