Reply
Nighthawk X4 R7500 Seiten sperren
Ducatiman
Hallo zusammen,
Ich habe im Menupunkt Sicherheit auf meinem Router Seiten sperren Aktviert und ein paar URLs eingetragen.
Nur das Komische ist das meine Gerät über LAN die Seiten blockiert werden, aber alle Geräte über WLAN nicht.
Hat hier jemand eine Antwort für mich.
Danke zum Voraus
Message 1 of 7
ElaineM
NETGEAR Employee Retired
Re: Nighthawk X4 R7500 Seiten sperren
Hi,
Can you elaborate more on what you're trying to achieve?
Are you having difficulty blocking sites on wireless devices?
How do you block sites? Is it through Block site on the router or Live Parental Control?
What's the exact model version of your router? Also, what's the firmware version installed on your router?
ElaineM
NETGEAR Community Team
Message 2 of 7
Ducatiman
Hi,
Yes
If I go then lock in Advanced mode under Security on pages.
Do I add a gap that needs to be blocked.
All devices on Lan are blocked and all about no WiFi.
My firmware is V1.0.0.94
Regards
Jim
Message 3 of 7
ElaineM
What devices are connecting to the WiFi?
Are you sure that these devices are connected to your own SSID or wireless name of the router?
Or perhaps, if they're mobile they might be using the data plan.
ElaineM
Message 4 of 7
Ducatiman
Hi,
I am sure that my devices are connected to my SSID.
I use Apple devices Mobile.
what is a data plan?
Regards
Message 5 of 7
ElaineM
Data plan is a mobile subscription for Internet.
If the wireless devices are still not being blocked, I suggest that you reset the router and reconfigure.
Push the reset button for 10 seconds.
ElaineM
Message 6 of 7
Ducatiman
Thanks for the answer,
I will try in the next few days.
I will then give the answer
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2013 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
