Reply
Nighthawk X4 R7500v2 QoS 'Apply' Button Grayed Out
okno13
Follower
Hi. We've had this router since June 2017, and it's worked pretty well so far. We made a few adjustments upon getting it. We changed the password and name, and turned off Dynamic QoS. Recently, my family and I have gotten a bunch of new devices (thanks IoT) and since we have over 15 devices on a 150mbps/down connection (>10mbps/device), we decided to turn back on Dynamic QoS. Upon doing this, we are greeted with a bandwidth test. It doesn't move.
You can literally type in the box, and the box didn't move for 10min. I decided to just look at what we had bought, which was 150/40mbps. I typed that in, and turned on Dynamic QoS. When I went up to click apply, the button does not work.
 Any fixes, or reasons this might be happening?
Other Details:
Model: Nighthawk X4 R7500v2
Firmware: V1.0.3.26
OS: Windows 10 Creators Update
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 1 of 3
JamesGL
Master
Re: Nighthawk X4 R7500v2 QoS 'Apply' Button Grayed Out
Hi okno13,
I did not get the same issue.
Message 2 of 3
JamesGL
Master
Hi okno13,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 626 views
  • 0 kudos
  • 2 in conversation
Announcements
