- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4S (AC-only mode)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi. I want to ask Nighthawk X4S owners if they are able to set the 5Ghz band to AC-only instead of a/n mixed? My goal is too buy this router and set it to AC-only for 5Ghz band ,and N-only for 2.4 band. I'm looking to buy a new router and I am still deciding between the X4S and the Linksys 1900ACS (this Linksys can be set to AC-only on 5Ghz band). Not being able to set the 5Ghz to AC-only would be a deal killer for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Nighthawk X4S (AC-only mode)
If you connect only -ac mode devices, it'll run at that speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That option is not there, I have asked for it many times. Hopefully they add it in the future.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Netgear routers usually specifies on config. the upto xxxx speed. So you set it to max. and when you have only -ac devices are connected
it'll run at max speed which is -ac mode. Don't need to specify -ac mode only. I am using same router at home. That 's the way it works. If
you mix -n and -ac devices then it'll run at -n mode speed to accomodate -n mode deivce.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I think he understands all of which you mentioned however in some instances its actually useful to have an "only" option, though for most it may be pretty trivial.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Specially when I get it free, LOL! One of perfectlly working MU-MIMO router out there. Asus >> Netgear >> Linksys going around.
Time to try Asus RT-AC3100(aka RT-AC88)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@VE6CGX wrote:Netgear routers usually specifies on config. the upto xxxx speed. So you set it to max. and when you have only -ac devices are connected
Just a slight correction. It runs at -n mode speed while communicating with a -n mode device and at -ac mode speed with an -ac device. The presence of the -n mode device does drag the overall network throughput down, but it's not as bad as it would be if the router were running at -n mode speed all of the time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Does it means in order to get the best out of R7800, it's better to have -ac device connecting to R7800 and add another AP/bridge for -a/g/n traffic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Sure, it would be best to only have -ac devices. You can get a separate AP for -b/g/n clients, or you could force them to use the 2.4 GHz band. But what do you hope to achieve? Your Internet service is likely going to be the bottleneck, unless it's Gigabit speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
-ac devices on 5 GHz, the rest on 2.4GHz won't do it?
